67.5kWh to 67.7kWh pack capacity (possibly the degradation threshold), assuming all pictures at a true 100% displayed charge level.
I assume your car still displayed 279 miles at 100%.
Anyway if so, that ~67.6kWh is the degradation threshold (with about 242Wh/mi constant). I would adjust your starting "when new" number in Tessie to 68kWh. That's probably about right.
You'll start to show rated mile loss when you drop below the threshold, so the first hint will be around 67.4kWh.
I hope this addresses your original question about your original capacity. We can say for sure it was above 67.6kWh or so. And given passage of time, it was probably around 68kWh. (
@AAKEE could back calculate for you (haha), but we can't actually do that and get a final answer until you show rated range loss. Right now, he could give you a back calculated minimum initial capacity, but not your actual initial capacity.)
