Nope it was neither.
EU/UK Model S cars all have dual chargers in them. Well... the UK ones certainly all do.
You can see this if you connect a single charger car to a 32A single phase source, set a current limit of say 28A, and start charging. The car ramps up from 0 to 14A, then pauses, then ramps from 15-28A. That's because the master charger starts first, checks the supply quality, and then powers up the slave. On the other hand if you set a limit below 16A the car just runs immediately up to that power level, because the master charger can handle it on its own.
If you only pay for single charger then the car limits itself to 16A per phase on three phase sources.
Tesla considered "bridged 3 phase" in the UK to get around this but changed their minds.
Getting 40A into the car single phase using this sort of unconventional wiring is fine, but I am skeptical that they will ever deliver 80A since there's no way to signal 80A pilot on a Type 2 connection, and the cabling/connectors are only rated to 63A for AC.
