mknox
I'm curious about the level of detail the signatures contain though... I assume they simply look for a bump of an approximate amount of power.
Essentially, yes. It does depend on the resolution of the data that they (Bidgely, for example) receives. I am guessing that data from your smart meter has a resolution of 1 hour, meaning that the meter takes a "snapshot" of your consumption every hour for a set of 24 data points daily. Not very granular, but they claim it's enough to figure out major appliances like air conditioning and electric vehicles. The Zigbee module in the meter could be configured to send more granular data to the Rainforest device, but I do not know how BC Hydro has these set up. The data feed I send from my TED is at a resolution of 10 seconds, so much more granular. But even then, I find it is not 100% at figuring out what's what. Part of it might be my problem. For example both my EV and water heater are currently on 20 amp, 240 volt circuits. I shut my water heater off with a timer such that it only runs during off-peak times. So when the water heater fires up, it runs for a couple of hours straight sometimes if I've used a lot of water during the day, and I don't know how they'd distinguish that from my EV which pulls the same amount of steady power when it comes on.
