Yes, I have questions:
1. Does it affect range?
2. Does it affect durability?
3. Does it affect AWD driving stability in adverse weather?
Would be nice to get a little discussion / opinions on these type of questions
Kind of tired of the motor debate going on and on with no end.
Would be even better if Tesla provided this as part of the sales process of selling a $2000 mod.
Is more power to the front true throughout the acceleration range or only kick in under heavy acceleration? Knowing that would help answer these questions.
I did buy the upgrade, below are my opinions (which are from someone who knows nothing)
1.) It will affect range if you mash the pedal ; most definitely. You now have more power available. I don't see why efficiency would be worse if you drive conservatively, stay light on the pedal. Bigger question if you purposely drive efficiently is it the same or is it better since the upgrade sends much more power to the front wheels now? EPA got better range in their tests out of the 3P- on 18's this year than the regular AWD and maybe it is for that reason? Or maybe the AWD had 19's on it that they tested? Not sure anyone knows because Tesla provides nothing on this.
2.) Should not have a major affect on durability. I think that is why this upgrade is fairly conservative ; only getting half way to the Performance. The rear motor power has been reduced a little so definitely no durability concerns there, the front motor now gets more but don't see why it cannot handle it. Outside of the motors the Performance and AWD are the same parts so it can obviously handle halfway to P power increase.
If they did push to full performance if the rear motor can handle it I think the durability concern would be more of a factor here.
3.) My uneducated guess would be stability should actually be improved given the front wheels are now getting more power than before. Seems like that would be a benefit to this upgrade for adverse weather conditions.
Other questions:
Tire Tread Life: obviously if you mash the pedal you will go through tires faster now with more power underfoot. But again if you drive very conservatively does more power now to the front = more even wear across tires and less need for rotation?
