Is 24 Amps the maximum you can charge the TMX? I use street charging with 22 KVA and 50 KVA and the maximum i can select on the car is 24 AMPS...what a waste to be connected to a 50KVA and use the same charge rate as on the 22 KVA...
I would also love to be able to select the charging amps on the mobile app. Sometimes at home plugs (220V) i want to lower (or raise) the amps due to other home equipments being used and am unable to do so remotely.
