Our 22 MX has a power usage meter in the bottom of the display behind the wheel. Show progressive white bar as you use power and progressive green bar for regen amount. I gets stuck in a mode where there is a long bar displayed all the time and it is either white or green depending on if you are drawing power or in regen mode.
The bar is always the same size and does not move according to the amount of energy used or regen amount. A reboot will correct this for a short time and then it goes back to this display. Anyone else seeing this?
