Is the powerpack spec on cycles out somewhere? Please link to it, so we can verify the 5000-10000 cycles warranty. I vaguely rememebr LiFePO4 has 4000-6000 cycle lifespan. Will be curious to see what is warranted number of cycles for Powerpack and Powerwall.
The powerwall comes with a ten year warranty, and is intended for daily cycle, which works out to 3650 cycles. The warranty can reasonably be expected to cover substantially fewer cycles than the actual projected lifespan. I can't buy a car with a 15 year warranty, even if it will last that long.
The exact lifespan remains to be seen, but 5,000-10,000 cycles is a good bet.
Second para: Agree in concept, disaggree on the positive spin you put on "more than twice". So, if it sucked up 100 MWh to produce 25 MWh of energy when needed, you will spin it as "more than 5 times" ? That's ludicrous!
The hydrogen proponents argue for the exact thing you describe - "efficiency doesn't matter if the energy is free"-type argumentation. But okay, I'll moderate my argument to say that you get twice as much balancing power for the same MW-rating with batteries vs natural gas peakers. Not "more than" twice as much.
Your last para makes zero sense. You are comparing initial capital outlay for natural gas plants per kw of capacity with KWh costs of Powerpacks. Here is a chart of how long the natural gas plants work. 51% of the plants are 30 years or older. Let's say, they last only 30 years. Then, it is $1000/(30% of number of hours in 30 years) per kWh produced, which is roughly $0.012/KWh, using your $1000/kw initial cost.
A natural gas power plant doesn't really last 30+ years. *Major* maintenance is required for that, where they replace almost everything. Same thing with batteries - the Mira Loma Powerpack installation may still be operating in 50 years - they just need to replace all the batteries.
A powerpack installation can be expected to operate 13-27 years (5,000-10,000 cycles), which is more or less the same as a natural gas peaker.
You should just use the number I provided earlier from the utilitydive.com article. That is 7-8 cents/KWh including cost of natural gas.
kWh doesn't describe the balancing power of the installation, you need to look at the power. Let's look at a hypothetical situation, where you have a grid that has an average consumption of 2400 MWh in 24 hours, where the peak consumption is 125 MW and the lowest consumption is 75 MW, and the consumption climbs and falls linearly.
Using batteries, you could even this out by having 100 MW of base power generation combined with a 150 MWh/25 MW battery installation that you charge when demand is low and discharge when demand is high.
Using a natural gas peaker, you can even this out by having 75 MW of base power generation, and 50 MW of natural gas peaking. You have to generate 600 MWh of electricity from natural gas.
Using natural gas, you have to output four times as much electricity as you have to with batteries, and natural gas has to be one quarter as costly as batteries per kWh cycled to be competitive.
