All AP2 Model S/X can be uncorked. I had one of the first ones. Has to be 75D or 60D upgraded to 75D.
I have heard of some AP1 MX uncorked but not sure if that is universal?
I can confirm the AP1 MX can also be uncorked. AP1 MS are the ones that had issues, mostly because some MS75D battery packs didn't utilize the higher capacity design.
For $88k would you guys buy a 2016 P90D with high miles, around 33k miles, or for $85k buy a 2017 75D with low miles, around 10k miles? I’ve heard that the 2016 models have glitches particularly with the falcon doors but not sure what else. I’ve learned to generally avoid the first year models as they are fixing the bugs. Yes the 75D isn’t as fast but I think that they tweaked the 2017 to be faster. The 2017 75D 0-60 is now 4.7 seconds.
First things first. Let's throw out the 2016 and 2017, they mean nothing. Tesla made multiple changes in 2016 as they did in 2017. Some 2016 were AP1, some were AP2. Some had moving spoilers, some didn't. Some in 2017 had tow packages, others didn't, etc. I've had both a 2016 and a 2017 and both have been back for service the same amount. Some issues were the same, some werent.
Let's talk about a 75D vs a P90D.
Price: Wash. The price difference isn't significant enough that you couldn't negotiate to an equal price point, plus other non-immediate price factors to consider. You can give the edge to the P90D at face value.
Modability: Wash.
Both cars are upgradable. Both can be made into a P100DL. Both can be upgraded cosmetically.
Range: Winner: P90D. Do you need the extra 15 miles indicated, or roughly 11 real miles?
Official range lists the 75D at 237 miles of range, ~213 at 90% or 210 after some minor degradation on a used car.
Official range lists the P90D at 253 miles of range. ~228 at 90% or 225 after some minor degradation on a used car.
Mileage: Winner 75D, but how is the maintenance?
Both will have unlimited miles on battery and drivetrain for 8 years. The 75D lasting another [est.] year depending on service date.
Wear and tear items are the only potential area of concern, not from a reliability perspective but from a maintenance cost perspective. I'd argue that it's not mileage, but maintenance performed that matters more here.
- Has the brake fluid been changed?
- Has the drivetrain fluid been changed?
- Has the wipers been changed?
- How is the tire wear? Have they been changed?
Options: Unknown. What do YOU want?
I wanted a heated steering wheel. My AP1 did not have one. I wanted a 6 seater instead of a 7. There's things you can install after the fact, and things you can only get by trading in for another car. I wouldn't have said this a year ago, but the AP1 vs AP2 is becoming a larger factor in that options package. Of course that doesn't matter if you wanted a Tesla that doesn't have AP (my S doesn't but has AP2 hardware)
Performance: P90D. What performance is important to you?
P90D does 0-60 in 3.2s. A MX75D does 0-60 in 4.7. Owning a 75D, I've NEVER been out 0-60'd on the street when I've been intending to do a 0-60 on the street.
For handling purposes, the suspension settings are the same on both cars. As are the wheels (assuming 22's are optional equipment on the MX75D) But the P90D weighs in at 5271lb, the Mx75D weighs in at 5072lb, 200lbs or 4% lighter is significant amount. With that said, I've never felt like the MX was unacceptable through an aggressive jughandle or unable to hold a line through a cloverleaf.
For braking purposes, well...first check the brakes on the P90D. Not all of them came with red brake calipers. Then even if they are, I've never actually seen a side by side comparison of the two calipers to see the differences beyond paint color so I can only speculate. Typically brake upgrades don't reduce stopping distance, they help with heat management which allows more frequent hard braking. How much does that matter? This goes back to a track question. But this video also did some tests which showed some differences.
So performance it becomes a question of how often do you intend to do any of that on the street? How often do you intend to do any of that at the track, and what type of track?
Fun fact: The performance specs on a Model X 75D are almost identical to an BMW e46 M3. Some argue that is the best M3 of all time. [It is not, the e36 M3 with the european engine is]
There's no right answer here. Which Model X do you want and/or need? For me, the Options would be the biggest factor.
