2013 MS 85 upgrade to MCU2 then HV battery problem
Good to hear!
Well, I picked it up a couple hours ago and then it completely shut down again!! Here are the codes. Brand new battery!
I don't think it's your battery. Looks to me it's your drive unit (DU).
**** ... another 10 grand. Hopefully not.
Which code would indicate the DU?
It looks like the BMS codes happened while it was serviced.
BMS_f033
The Battery Management System (BMS) will trigger this alert when it senses a loss of contactor power while the contactors are closed. The BMS assumes that it could be because the pyro fuse on the contactor power supply signal blew during a crash.
This may trigger while a vehicle is in Service and the contactor power supply loop has been pulled.
BMS_f062
The Battery Management System (BMS) has detected that there is a power supply issue with the contactor.
Reactions: Espi2451
BMS_f033
BMS_f062
It happened while my wife was driving. Completely shut down. Hopefully it’s not the DU. I can’t afford another 8-10k. Luckily they gave me a loaner. The least they could do. Do you all think it was something different all along??
