I would like to use the 12V circuit to run an external device. How much current can the 12V circuit handle? I realize the battery is relatively small, but I presume that as soon as it starts to discharge, the inverter that charges the 12V battery from the main battery will turn on. So the question is how much current can the inverter supply? And if there is enough current available for my purposes (I need about 20A), where is a good place to connect? The cigarette lighter outlet is very limited.
Thanks,
David
Thanks,
David
