So my high voltage battery on my 2014 S85 is bad and needs to be replaced. I just towed it back from the SC and I can't find the fireman's loop - looks like they removed it but forgot to leave it in the car.
The 12V battery is dead - my problem is that I need to get the main screen on to get out of service mode but when I try to charge the battery with a power bank it charges for 30 seconds and then trips for some reason and stops charging.
If I try, the dash screen will turn on and shows service mode but then turns off after 30 seconds.
Any ideas why the 12V won't charge more than a minute? Should I try disconnecting Neg terminal and charging the 12V directly via the Pos bolt? Currently I'm charging via the terminals in the nose cone.
