Oil change in drive unit tesla model S
I hear you with that and understand, although my opinion is it's a pretty poor reason to avoid good maintenance practices on the off chance somebody doesn't put it back together right. What percentage of the time do you think that happens? I'd say 5% is awfully high. I, too, am a mechanical engineer by training.
The people that can't do anything right end up on Just Rolled In for our entertainment:
Reactions: dn325ci
Beside this research we did on oil for drive unit ,we also did figured out what was best grease to use in electric parking brake pump.
You can check thread where we posted details about parking brakes replacement ,cleaning and upgrade. Here is thread started by other member here we just continue with replying and adding some pictures ...
Parking Brake Sensor Disconnect​
This is thread we posted .
By the way thank you all for reading and giving tumbs up.
Together we are stronger and we will enjoy out Tesla S for long time.
Next tread( very soon) we are preparing how to fix charging port ...... removing warming light from dasboard and replacing magnet on the charging door.
Cheers
Here is some torque specs one of members here were asking for.
We got it from Internet 28 Nm.
In our case we just went a bit over green line that was marked on bolt and housing.
We think its good idea to replace this oil frequently .
We did every 60 000 km on our Hybrids Lexus RX 450h and ES 300h.
Never got any issue with CVT transmission and we used ATF oil from lexus.Same procedure like on Tesla S ,just drain and fill.
Also its good idea to recharge your small 12volts battery in Tesla S.
We are using Schumacher charger slow 3amp feed and AGM or GELL battery selection on charger. With combination of Aperol spritzer lol..
Cheers
I'm with you in that it's probably rare, at least if we are talking about mistakes leading to immediate catastrophic failure.
Not putting together correctly however: almost all the time from what I've seen. In the 20 or so used cars I've owned, I would say none of them were correctly put together after service. As an example; rarely seen an aero shield or a wheel liner correctly re installed. At best, they are just missing a clip, but often much worse. An authorized BMW shop that did work on my car routed a front wiring harness branch on the outside under the front bumper, completely exposed to the elements. Under carpet sound deadening and butyl water ingress liners are items that "mysteriously" disappear little by little every time work is done in the cabin or trunk areas. Small speakers are notorious for getting permanently disconnected any time work is done behind interior panels, resulting in a sound system that's not what it once was.
In fact, exactly this happened on my Model S when it got its trunk chinch actuator replaced by Tesla a couple of weeks ago. Not only did I lose the trunk speaker sound and beep at close but the whole trunk area now rattles like crazy because fastening clips were lost or broken.
While each of those faults may not be catastrophic on their own, they add up over time.
I'm not advocating for avoiding oil changes in cars that need it. Just saying that faults created during service is likely a factor in OEMs deleting service requirements.
I'm guessing this is what happened to my car? Somebody has definitely messed with the drain plug on my rear drive unit. Maybe the fluid was changed out at 12.5k miles per the service schedule. Makes me feel better but also uneasy.
Next time I'm near a service center, I'm gonna walk in there and ask for the service history, or at least I'm gonna try.
I had my 2017 S changed at 12k recommended interval…. They encouraged it back in the day.
Reactions: TLLMRRJ
My assumption is that early first drive unit fluid change was to clear out the debris after the drive unit was broken-in. Some manufacturers say they break-in their motors/transmissions before they are mounted and installed, but most don't.
Yup. I was just letting @dwbv it was common maintenance item instead of being worrying about the mark not lining up for nefarious reasons.
Wow, you're an unlucky guy! For me I'm going to err on the side of good maintenance. In my view, it hurts nothing and probably helps to change the oil in those drive units, and it's a very easy job to do.
Here is one interesting thing about oil change in tesla model S .
Dealer will not do it unless is problem with drive unit.
However we did change oil in drive unit regardless.
Dealership will not sell you oil also ,so we had to come up with alternatives.
It depends on the service center. I just had the oils changed in both drive units without any problem. I have a 150k on my S now and felt that it should be done and I will say I can tell a difference. It feels smoother and slightly more agile.
I want to change the gear oil on both the front and rear drive units on S. Ive been doing some searching around, seems alot of people say Dexron VI is compatible. I was trying to find something better in either Amsoil or Redline product line. I came across a fluid from Pentosin called ATF 64. Anyone had any experience with it? The company even released a statement touting it as compatible for Tesla. https://crpautomotive.com/wp-conten...tive-Pentosin-Tesla-EV-Fluids-Award-PR_V2.pdf
Reactions: FireFighterHil
Just adding my two cents to the debate earlier on whether this is required and why does Tesla say its not required etc. I got a new rear LDU replaced recently and over the past 200 miles, my efficiency has improved to the tune of 20-25 wh/mile. All other factors constant. 54k miles on original LDU.
If you have mechanical components lubricated with oil, change the oil regularly.
After pricing up what it would cost me to do it using the Pentosin ATF 64 and 2 filters, approximately 120 dollars. The Tesla service center will do it for 230 and can get me in next friday. Im just gonna let them do it. About the only thing I havent done maintenance wise since I got the car last year is flush the brakes.
almost a year driving with new oil dextron 6 only 2 liter and new quad valve with glycol G 11 concentrated new coolant and no problems since.
its not recomanded by tesla to replace any fluids unless there is problem.
however i do my routine replacing all fluids and lubricants and small 12 v battery its easy job.
tires and brake pads and rotors also once a year
and you will be always on the road no matter what
cheers
So does anyone here have any information regarding (1) whether Tesla will actually change the oil based on a customer request (is there an official policy?) and (2) what the warranty implications are if you DIY it?
Im scheduled to have mine changed this coming friday. I scheduled it through the app under "other maintenance"
Reactions: TarmacSurfer
