Guesses on whether the "Spring Update" will actually happen in the Spring?
Finally it’s here
I typically receive major releases every 40-55 days. 2024.8.4 was received on 3/19, so I am at 49 days, which is still within the typical window.
I received overnight notification that 2024.14.6 is ready to install. That would make 52 days since the initial version of the last major release. A little bit on the longer side, but shorter than 2022.16, 2023.40, 2023.26, and 2023.38.
On a separate note, for those that have installed 2024.14.6 and weren't currently subscribing to FSD, is your trial period 30 days, or is it extended? I thought that I read posts from those on the 2024.3 branch that some had trial periods greater than 30 days.
Reactions: boonedocks
It's 30 days. Just installed it. Message states, "This trial will end on June 9, 2024." I also received a separate message saying that FSD is enabled on my vehicle (single pull to activate), but I can disable in Autopilot settings.
I got the update prompt last tuesday, on my 2023 MS Plaid. I checked the release notes and it was this spring update.
But, I needed the car so couldn't l update at the time. A few hours later I checked the app again and the update had vanished. Doh!
No sign of it after that..
