Discussion: Powerwall 3 [Speculation / Discussion etc]
4:30 now at 89%, 12.4 kWh generated today, so this seems to be charging very slowly.
Sounds like you are getting solar and it is charging the battery, while also powering the house as needed. The rate of charging would certainly be affected by how much solar is being generated, and in a case of having 10 panels (as you mentioned) and factoring in weather, positioning of the sun, positioning of the panels, etc. it's certainly possible that not as much solar is getting generated and therefore not as much is going to charge the powerwall after some of that also gets used to go to the house.
Reactions: LiBeRtAs
Anyone want to compare charge rates for powerwall 3?
For instance, today sunny day producing 1.5 kWo’clock at 9 in the morning and the powerwall went from 62% to 63% in 10 minutes, took 10 minutes to go one percentage point.
Of the 1.5 kW .5 was going to the house and one was going to the powerwall.
Just thought I would put this here if anybody else with a new powerwall 3 would like to do a little comparing. I’m just curious thank you.
