TechVP
Active Poster
Here is my situation and resulting questions (please note that I am neither an electrician nor do I know much about electric circuits. I will hire an electrician for the install, right now I am just trying to figure out whether I need to buy one or two HPWCs):
Saw your post, and I have thought through a similar process as yourself.
One or Two HPWC's aside, I would definitely try to justify keeping your NEMA 14-50 as a backup. In case either of your HPWC's fail to charge your car(s) you have the next best option available at all times.
Next up your power budget. You mentioned that 100A is your max. This limit may not let you charge at a 80A continuous load. Fortunately you do have the option of dialing down to the next highest settings on the HPWC.
It may help to explain what limitations you have: Cable gauge, old wiring, distance, Main panel loading, attached or detached garage, etc.
There is a brief section you should read in the FAQ: Home Tesla charging infrastructure Q&A:
Jump to the section titled:
WHAT DO YOU RECOMMEND IF I WANT TO INSTALL AN HPWC AND HAVE A 14-50R AVAILABLE FOR ANOTHER EV OR BACKUP?
I believe this gives you the most flexibility to add a 2nd HWPC. As you are aware, two or more HPWC's share the load, and are designed not exceed the rated current. Having 2 HPWC's appears to be a smarter charging method, from my perspective. If, you can go that route.
Meanwhile, do try to keep a NEMA 14-50 as standby if it will pass inspection.
Comments / Suggestions welcome.
