It does seem like my system isn’t ideal…
Here’s what I’m currently using for pricing…
Originally the system was working fine in with grid charging off (I was pre PTO). So ESS was charging from only sun, and it had plenty of headroom each day. The SoC curves looked good, as it basically hit 100% or near that right around 4p peak rates. Though I could send to grid because I wasn’t PRO.
However, I got PTO the day after that photo…then flipped on grid charging. Initially I thought charging to some level starting at midnight made sense. Below it goes start to 66% SOC, then anticipates Solar getting it right to 100% during the day. This is ideal behavior I think. However, it only did this for a few days right after PTO.
Also, wouldn’t it be better for the ESS to wait for the grid charging until as close to 3p as possible? Then it knows more about that days PV production more accurately. It can minimize grid consumption, and NBC’s.
However, what it eventually wound up doing for last several weeks is this. Basically at straight to 90% after midnight. It doesn’t make any sense to me. It then makes me need the Charge on Solar feature to prevent from generating too much off peak so I don’t exceed the monthly PVWatts limits on generation.
Also, I can’t understand why my system goes straight to 5% reserve (my setting) at 4p. It leaves no SoC above 5% reserve for the 9p-12a shoulder, which isn’t cheap. And almost 25% of the time it actually consumes a bit at peak rates even because it’s dissipated the SOC down to reserve.
Any insights to adjust (rates?) would be appreciated.
I thought about maybe turning off grid charging, but then that won’t ensure I max out SOC each day so I can put max onto grid at peak rates (under the PVWatts threshold) for NEM2 swapping later in winter.
