aerodyne
2 of 3 EV's - Defect Free!
2. The frunk latch doesn't always unlatch. You pop it, but then you can't lift the frunk up and there's no way to manually release the latch with your finger. The only work around I have figured out for this is to pop it with your phone while you are standing in front of it, but before you tap open on the app, pull up on the frunk lid, that way it will unlatch all the way. Highly annoying there is not a physical release or at the very least a button like the rear trunk you can press on the body.
Try adjusting the rubber bumpers on the Frunk lid inner surface, by twisting a 1/4 turn at a time. My guess is the are screwed out too far and are preloading the latch mechanism.
You can also tape shims where the above bumpers contact the plastic frunk surrounds either side of the latch, to get a feel for the adjustment needed.
Don't go to service unless you want scratches and stuff broken.
Mobile might be an option if you are mechanically disinclined.
