I only have auto-open enabled. Auto-close has been off for ~6 months because this has happened to me before several times when i try to back into the garage after washing the car in front of the garage door.
Today I was backed into the garage like always and just put the car into drive and it tried to close the garage door on top of the car.
I've reported this homelink stuff several times and they act like they cant troubleshoot it remotely and that is as far as it goes.
Thinking about this a little more.
Your car is in the garage for a while. You get in and “start” the car (hit the brake). It could easily have a poor GPS fix a block away. As you drive out it gets a good/better GPS fix. It thinks you just arrived home and sends a door command to change the doors state (closes it). It doesn’t know if the door is up or down. Boom. I often click the button to open the door on the wall as I enter the garage.
You're depending on GPS to change the doors state regardless if it’s up or down (because it doesn’t really know).
So I just had this heated debate with a buddy of mine on how safe this is to use.
He uses Auto Open AND Auto Close and says it's been flawless for 9 months.
So we are both guessing somewhat of how this blackbox works and we both agreed that it might be that's it's actually more robust to have Auto Close ON, believe it not. I was always thinking Auto Open only would be safer. Here is why.
The reason is Auto Open uses GPS (which can be glitchy sometimes, especially at start up in the garage).
Auto Close (when leaving) does not use GPS.
So when you leave it's in "Auto Close" mode and it won't close the door until it thinks you are 30 feet away (distance is counted down on the screen). It uses the cars tire rotation to measure distance, not GPS. It won't "arm" Auto Open until the Auto Close has run its course.
So by using the more reliable distance method for Auto Close it will never do anything without being 30 feet away. Including Auto Open (which it can occasionally get wrong) but that won't get armed until it's done with Auto Close.
I still won't use it in either mode though.
