Good info appleguru. We need to be aware of the drain on the OBD II port. Mine is a 2017 AP2 S. And I blew that fuse a few months ago. It took me a while to figure out where the fuses were, which fuse it was. Even after I knew it was F219, the panel does not show you the label for the fuses. I learned the hard way that the OBD Ii port fuse was blown because two things would not work that were plugged in. And I agree with you, it powers the Glove box light. But SURPRISE, - SURPRISE it power something else less obvious, - the TPMS. The fuse panel is behind the passenger side kick panel. You have to remove the passenger side door sill trim to also remove the passenger side kick panel (under the dash).
I have the diagram (found it on TMC) for the fuses labels. I had to use a link to get my copy, because the TMC post said it may be proprietary info and should not posted on TMC. So, I too will not post it here. However, if you want a copy, PM me your email address and I will send you a copy.
(People make a note of this: And anyone that disagrees with me about the following info, please correct me. ) Fuse F219, right side column last fuse/and mounts horizontally is the F219 5 amp fuse. F219 is the last one in the column where the fuses are horizontal. (There are three fuses below it that mount vertically, F236, F237 and F221). F219 for the OBD II port also powers the glove box and the TPMS system. If the fuse is blown, the glove box light is out, and the TPMS birdseye view of the four tires will NOT display when you bring up the car's health on the instrument panel/dash. It simply will not display. Fix the fuse and bingo the glove box light works and the TPMS view returns (and the OBD II has power again. I've not found this info documented anywhere. Save the link or copy it some place where you can find it when you need it.
