M3P Front Passenger suspension squeal/squeak
Hi, recently noticed my FR Passenger suspension starting to develop very light squeal/squeak sound from the suspension. The car is at 73k miles and nothing been done to the suspension to date. The car upper control arm ballpoint was serviced through the service bulletin a while back. I took the car to a local shop and he advised my lower control arms to be replaced due to worn out bushing. However, this didn’t seem to fix the issue with the squeal. Anybody know what could be the issue? I’ll try to record the sound next time.
The service bulletin of injecting lube into bushing is only a temporary fix. Sounds like you need the upper control arm replaced. I've heard they often waive the labor and only make you pay parts, even if you are out of warranty. $200 each I think. Even if only one is squeaking, I'd replace both.
Does it sound like this?
Reactions: moojimmy
