Gruber has a video showing an oscilating tool. The blade needs a step in it to work correctly. I used the side of a breaker bar which wasn't ideal. Also - I also cut one of the coolant tubes during the lid removal which caused a giant PITA so proceed carefully. Some of the coolant tubes can be right at the union of the lid and the case.Amazing write up. I have BMS_u029 error. Gonna drop my 14 module 2013 Model S60 and replace module #9 showing low voltage on one brick. What are people liking for tools to remove the lid? Anyone used an oscilating tool yet? Thanks all!
My 2014 was December 2014 but the battery was replaced in Q1-2015. It was a new pack and I'm not sure 'why'. The original owner mentioned it, but I didn't know enough at the time to ask more details.When was your MS built in 2014? Mid 2014 or late 2014?
Nice. In some ways I wish I had more time and a garage to work on the pack my self (have knowledge and skill) but it was almost cheaper to buy a new M3P. I miss the off the line torque the P85D Ludicrous had, but not the fall off after 30 mph.My 2014 was December 2014 but the battery was replaced in Q1-2015. It was a new pack and I'm not sure 'why'. The original owner mentioned it, but I didn't know enough at the time to ask more details.
LOL. Dammit.I bet you a six pack of your choice the two 'bad' bricks were totally fine and the capacitors on that BMB just rotted out. There is no way 148 cells each dropped a full volt without the fire department being aware.
I am in process of removing the modulesMack,
Since you have the pack open, I would recommend checking all of the modules carefully. There are 112 sensor wire connections plus the BMB boards to check. I poked all of mine with a plastic tool, cleaned each with 200 proof alcohol and recoated each with another layer of conformal coating to help insure no moisture gets in. I did the same with the capacitors on each BMB. It took a lot of time (10 hours?), but when one thing fails in these, there are a LOT of similar connections/components that could be right behind.
It depends on which version of battery pack do you have, version 1,0, 1.5 have pyro fuse on top, which can be replaced after dropping the HV pack, version 2.0 pyro fuse cover is at the bottom of the pack which can be replaced by lifting the car upfyro fuse Can the pyro fuse cover be inspected without dropping the pack? Is there a view through the frunk?
