Yoke Creak?
habanero69
I Dont Need Cialis. I Drive an EV.
Jul 29, 2016
452
276
KY
New 2023 Model S, 5 days new. So thrilled with it as it replaces my S 2016 and it's like a whole new level. Anywho, I have what sounds like a small creak or bind sound coming from the yoke when I make basic left/right turns. It is not every time, and it seems like more frequent at the start of a drive. It's not very loud, but I'd like to think I could resolve. If music is on I almost never hear, but that's not the solution I was looking for. I may try and get an audio of it from my phone, but not sure it will be enough to assist.
Thanks in advance.
Thanks in advance.
Does not appear to be a common problem.
Might be a new one caused by the EOY rush.
Try adjusting the yoke in/out and up/down to see if it goes away or changes.
Bummer. Will try the yoke reposisiton over a full range of travel multiple times and see if that resolves. I defintely will give it some time before a service consideration. It's just not that bad. Yet.
If you can avoid the SvC, I would. Likely to not fix the issue and break something else in the process.
Mobile can replace the yoke easily, if it turns out to be the problem.
