The ONLY thing I had to suggest is an option while backing up that instead of the inside/out behavior, it does the knight rider sweeping but in bright white instead of in bright red. You've obviously thought out the options and they are all VERY logical. Thanks for doing that.
Will add to config options
I do have another question. First of all, I'm super happy you guys found an "always on" 12V. Is it on even when the car is off? Or is it on only when the car is on but even if no lights are on? Was curious about that... I have my front Tesla T glowing on and off ALL the time, even when the car was off. I wanted to do the same thing with the applique and maybe even my rear Tesla T now that the power wire is there (if it's a true always one).
My reading of the Wiring Diagram indicates it is truly always on. Regardless of sleep state, etc. It comes from the same 'bus' as the 12V 'jumper post'. It has a few fuses along the way, but no switches, control modules, relays, etc. That makes me believe it is always on.
However...
I don't have access to a car to physically verify at this moment. I will have such access by next week.
The connector is X961:WWMB2, pin 17, wire color RD (which is red) if you wish to verify yourself. This connector is somewhere on the right side of the trunk area, and will have LOTS of wires going to the right tail light assembly.
- - - Updated - - -
Can (will) the applique be powered off when the car is off? I don't want the applique to be drawing any electrical power when the car is OFF, with the possible exception of the letters glowing green when the car is charging (assuming an inductive sensor has been designed for sensing current flow in the charge port, as I do not wish to make any electrical connection to the charge port).
Power: Yes, the module will draw about 0.13 Amp at all times. This will remove 1 mile of range from the car every 11 days. If you wish it to not do this, simply run a wire to a 12V source that goes off when the car is off. At this moment in time, I do not see such a source anywhere in the rear of the car. There are plenty of choices up front. Therefore, each installer can decide the tradeoff between running a wire up front, vs. a vampire of 1 mile per 11 days.
Of course, choosing a wire that goes off when the car is off also means that nothing can be displayed with the car off. For example, the car cannot "Knight Rider" scroll, or "Breathe TESLA S" or similar, when sitting parked, if the power is off.
Charge Port: R1.0 will not support charge sensing. I'm not certain at this time that we will ever be able to sense charging.
Also, is there (can there be) an option to just have constant White lettering "TESLA" when the car is in reverse, rather than the "strobing" way the chart indicates?
Yes, will add this to configuration options.
- - - Updated - - -
And for the 70's 80's guy in me -> 5) Disco mode. Make it more spastic, 110-125 blinks per minute ? :tongue:
Will do.
- - - Updated - - -
If you add new behaviors can they be added later via Bluetooth?
No.
- - - Updated - - -
I late to this build so I am OK with anything the group wants. My ONLY concern is that we can easy choose to not use certain features that might not be legal or a little 'over the top' for an individual's tastes. This can be Accomplished by not making certain connections....correct ?
Correct. A given wire not hooked up = no behavior at the applique when that wire's light does its normal thing on the car.
