I agree the tracking is a maintenance item, however the poster has only had the car a month tops, Its pulling to one side and the steering wheel isnt central - I suspect just looking at the tyre wear will confirm the tracking is out and that couldn't be done in a month of normal use.
If the tracking is out then the first sign on the tyre is feathering of the edges on the blocks of the tread, If its significantly out it will be wearing the edge of the tyre - so measure the tyres at the outer, the middle and the inner - they should all be pretty much the same tread depth
The tracking itself is a simple and quick job to do - centralise the steering wheel, clamp it in place - check each of the wheels for alignment and adjust the track rods to ensure its tracking straight - Its just one nut to loosen each side and a pair of mole grips to turn the track rod to screw it in or out. Its as easy as fixing meccano together. I really cant see Tesla - or indeed any car dealer arguing the toss over something so minor and so soon after supplying the car --- unless there is damage sustained that explains it was caused by impact - and at the end of the day its a nil cost fix apart from maybe 30 minutes of someone's time to do.
If it was my car, I would argue the toss, quote the consumer act, show them a copy of the act, and if they still decide its a charge for job then take the car and have a Hunter alignment check with someone with a fantastic customer service record, Whatever the bill is that would be paid and presented to Tesla to reimburse and tell them if they don't then you will be taking them to the small claims court to recover that outlay - in legal terms "damages"
A Hunter check will undoubtedly find other issues with all 4 wheels and suspension - that will be documented and will strengthen your case that Tesla failed to correct existing issues - which in legal terms is negligence under the law of Tort - They failed to do something they should have - or - did something they shouldn't have done.
Tesla may be hardnosed about penny pinching but they are not stupid, they couldn't possibly win the case unless they can prove you damaged the car, so will not challenge a court case - They may push it to the limit but once served the papers to summon them to court they will settle and compensate, but i honestly cant see even Tesla going this far - They will rectify for free.
@yessuz I agree with what you say but the tech and manager at Nottingham isn't Tesla - they wont be the ones defending in the court and whilst i also agree that potholes and kerbing potentially could affect tracking its for Tesla to prove that - not for the owner to prove they didn't. The consumer Act is a super piece of legislation that most car retailers tend to pretend it doesn't exist - they hate the fact every car has a 6 month absolute warranty and any fault is deemed by law to have been present at the point of sale - unless they can PROVE otherwise.
