Joe,
This may be a stupid question, but I am new to your program (and the car) and am trying out the different things. I set a notification to tell me if the the car is unplugged at 10 pm, so that I can be sure to get it plugged in prior to the start of charging which I have scheduled on my Telsa at midnight.
I got these two text messages which I think are triggered from that notification but am not sure.
First text, just after 10 pm "(VisibleTesla Notification) 2013-12-19 22:00:56 Input Power is less than 1.0"
and then this text at 4:22 am "(VisibleTesla Notification) 2013-12-20 04:22:28 Input Power is less than 1.0" - which is when I would estimate the car would have completed the charge for the night. My question - is it the "Unplugged at time:" notification that is sending these messages and what do they mean, because the car was plugged in and I got a full charge or is it something else that is triggering these notifications that I don't understand?
Hello Snosrep. Not a stupid question at all. Yes, when you get a notification that says "Input Power is less than 1.0" that means the car is unplugged (no input power). The first notification you received at 10PM is what you should expect. The second notification the next morning is a bug. This bug was reported by another user (dlmorgan999) and is fixed in an as-yet unreleased version of the code.
- - - Reply to scaesare - - -
So I had a chance to play with notifications this evening. I have all of the notifications enabled, but so far the only ones that should have triggered are:
Unplugged at time: I had this set for 11pm (and left the car unplugged for this test). That time came and went with no notification. However, I am allowing both the car to sleep as well as the app to sleep after inactivity. It appears that app will not wake the car up to specifically test for being unplugged?
That's right. The Notify tab never wakes up the car by sending it a query. In fact, the Notify tab never actually talks to the car at all. It just monitors what the other tabs are doing and when it sees interesting data wander past, it checks it against the notifications. This minimizes extra traffic to Tesla's servers but may result in a notification being triggered up to 2 minutes after the actual event occurs.
Charge State Becomes: I plugged the car in and got two notifications- 1) Charge State took on a new value: Disconnected, and shortly thereafter, 2) Charge State took on a new value: Unknown. These appear to coincide with the time that I popped the charge port door and then plugged the cable in.. so perhaps those are the two events represented?
Yes, that's the correct interpretation. The value returned for Charge State is a little squirrelly. There is no "Connected" state so Unknown gets used at times when you think it might say Connected.
So my question: is there a combination of settings that will allow Visible Tesla to run on my machine, and yet allow the car to sleep (for power savings), and be woken ONLY for the specific events that require it, such as checking the plug state at a set time?
No, not at the moment.
For that matter, if the car is sleeping, to I have to explicitly schedule an Awake command prior to an HVAC: On command in the scheduler if the car will likely have fallen asleep prior?
Technically the "HVAC: On" command should wake the car up. I always wake my car up first, so I would be interested in hearing from other users that do this on a regular basis if this works reliably without a prior wakeup.
Thanks for the development on this, and any answers to my questions.
Thanks for the ongoing testing.
