Cool I am to chicken to start splicing into wires
I need something that is possible to hide, like V1 in the back mirror, because radar/laser are not allowed in Norway :-(
Or simulare something that laser could be hided and use my mobilephone to warn me when police aiming at me
I actually don't mind buying another V1 and mounting it rear-facing, and mounting a separate one front-facing. That's fine with me. It's a knowable $500 cost that I can choose to buy or not.
I looked behind the nose cone. It's probably doable, but it is very close to the radiator and I would not want to impede that functionality. Wiring should not be an issue, should be very easy to route a phone cable to the fuse box or OBDII port for the Savvy.
I'm considering taking my V1 apart to see if the detector component could be removed, and placed into a custom-designed housing that fits flush with either one of the side mirrors, or another to-be-determined location. Maybe it has separate front and rear detectors that could be separately mounted. Not sure yet. Trying to avoid this level of complexity to resolve a fairly straightforward problem.
With regards to the "open" area of the windshield, it looks like it should actually be large enough to fit the front detector portion of the V1, but the rest of the V1 body gets in the way.
Any update on the V1 behind the nose cone? Does it do the job for you? Any laser alerts come through? Are you using Valentine's add-on Bluetooth module to send the display to an iPhone or Android device?I put my V1 on the bumper beam behind the nose cone and it seems to work quite well for forward facing assaults. I actually "shrink wrapped" it with my Food Saver to protect it from moisture and it is working so far. I also already had a remote display for visual alerts, but needed to buy the remote audio controller to have audible alerts. 50 bucks. The cheapest fix I could figure.
One warning: I attached the accessory junction box, which connects the V1 to the remote displays (audio and visual) to the outside of the frunk "box?" on the driver's side and it failed after one rain storm. I didn't see any evidence of moisture, so it may have been happenstance, but I ended up taking my other one (I have so many spare parts for everything...) and placing up under the dash cowl to the direct rear of the funk, outside the cabin, where it can't get wet just in case. No rain since, so I don't know if I solved the problem.
It is not an ideal installation, but it works for forward radar (and laser? Don't know). I would like to go for the whole Escort solution, but it is just not in the cards right now. So I do feel vulnerable.
I have been a V1 user since the day they were released and it has never failed me and has saved me thousands in tickets and insurance. I hope they come up with a viable solution. I called and spoke to them and they said they had nothing on the horizon and no immediate fixes at all. Bummer. I expect the relatively low volume of the MS makes it hard for them to justify the big dev costs to create a new solution.
I'd like to put my V1 to use. Any insight is appreciated.
I have had many verifiable forward radar alerts from a surprisingly long range, so I am happy with that. I have had a few jammer alerts, but no laser alerts that I know of. Though I don't think we are using much laser in my area. It has never been a big alert for me. I really do miss the rear and side alerts. But in practice, it has caused me no problems as of yet. It STILL has not rained out here, so I can't comment on my cheapo waterproofing solution. All in all, it seems to be working very well, given the environmental limitations.
I still want the Escort solution. But no moolah to pay the monster price.
If you have pano roof there is a drain tube. If no pano roof there is a plug you can use. You will have to drill a bigger hole for wires if you have pano roof
... Anyway, you can run the wires up either side of the front (under the large plastic trim pieces) and go under the weather stripping at the "A" pillar into the cabin. Very easy.
Couple of quick comments. I'm also a huge V1 fan for at least a decade if not longer... it didn't work in my July '13 P85+, even behind the "dotted" area on the windshield.
I ended up trolling ebay for a while and found a used Belltronics STir+ unit (a twin to the Escort 9500ci but better) for $900, including three laser shifters. I had a pro shop install it for about $1000 (I was originally quoted $700). So all in, it was about $1900 -- a lot less than buying new.
Before that, I also tried installing the V1 in the nosecone with remote display and remote audio, and no drilling of the firewall is needed. (It ended up not working well at all -- couldn't get any radar or laser alerts at well known speed traps unless I was right on top of the LEO). So I pulled it all out and put the Belltronics in instead. Anyway, you can run the wires up either side of the front (under the large plastic trim pieces) and go under the weather stripping at the "A" pillar into the cabin. Very easy.
