First, the backstory. Skip to the bottom for the actual question.
My AWD came with the 14-50, and I actually used it on my first road trip. We did an AirB&B over Memorial Day weekend, and I arrived there, after 15 minutes at the enroute Supercharger, at about 30% SOC, expecting to use the front door 120V outlet to trickle up for errands and the drive home.
But, the house was wired in the 1950s, and its 120V outlets were two wires only: hot and neutral but no ground. Without a ground on 120V, UMC no worky, I learned.
Fortunately, there was an RV campground about 200 yards down the road, so I gave the owner $10 to let me charge for a few hours on a 14-50. Worked perfectly: 32 amps and 30 MRPH.
The question:
If I bought a 3 prong adapter and then used a wire with two alligator clips to connect the tap on the adapter to something grounded (a metal pipe, the breaker box ground, etc.), would that work and be safe?
I'm pretty sure it would work, and my rationale is that if the ground failed or was faulted to a) the UMC would shut down the flow, and/or b) a breaker would trip. But, there are smarter electrical minds here than mine. What say you?
Pics:
The question:
Pics:
