I then tried Michelin and they lasted about three months before getting noisy
Was that these 'stealth' ones? New wipers big difference
My originals are now 10 months old and wiping well, and quietly. I’ve seen others complaining so I wonder if it is a question of which batch the OEM wipers came from?
I've purchased these. They do fit apparently using the original fitments from the Tesla blades, which I still have.
https://www.amazon.co.uk/gp/product/B013VDWXTI/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Halfords stock Bosch so maybe more info in store there? If you are member of AA breakdown and other organisations, you get 10% off in store at Halfords.
[ouch]Bosch A120S Wiper Blades - Front Pair | Halfords UK but does say not suitable for vehicle and so does Amazon linked ones.
presumably £26.10 per pair Vs £42 per pair ( plus postage probably)
These arrive for lhd cars, but all you need to do is swap over the snap in fitments from the originals on your car and they become rhd fit.
Detailed instructions/video please!These arrive for lhd cars, but all you need to do is swap over the snap in fitments from the originals on your car and they become rhd fit.
https://www.amazon.co.uk/gp/product/B013VDWXTI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
£26.10 the pair. I've just fitted them to mine. They also have the Bosch logo on them, which my original ones didn't have, so I wonder if the originals were Bosch.
I bought some similar style ones cheap once that turned out to be LHD and had to do something similar. the end caps come off and then the sleeve and then you can take off the connector in the middle. I assume its something like that?Is it obvious what bits need to swap over and how to do it?
Even though they dont list it for our cars (a lot of sites arent up to what fits a M3) I can confirm they fit and work perfectly (better than original)
Go into car and select Service and then wiper service mode
Remove original wipers (pressing down on button) lay down arm with a towel or microfibre under arm over glass.
Remove both small clips on new wipers (turn them upside down and push until they click off then remove.)
Compare wiper length (I think the 19" is driver and 26" passenger)
Slide TL4 connector (there is about 4 or 5 different connectors) into wiper arm till it clicks then take new blade and position under new clip give it a firm push until it clicks into place. You could always put the TL4 onto new blade first then slide into place but I found putting the connector in first then the blade easy.
Repeat with other blade.
Go back into car and take wipers out of service mode (when you put the car into Drive it will also do this).
I have found them so much better than the ones that came with the car.
