I think i'm nearly there.
So, the car is supplied with a 16amp 7.5m Type 2 to type 2 which is suitable for ( type 2) podpoint home charging & `16amp fast charging & 16amp medium charging. Not Chademo unless i manage to buy the adaptor & 32amp cable.
I shall buy the Tesla UMC cable with a uk 13amp 3 pin adaptor & a shucko EU adaptor which will allow me to charge at uk family & friends homes & eu vacations.
If i use the UMC plugged into the ( French ) socket can i use the tesla type 2 to connect to the UMC & Tesla charge socket? if not. what can i buy online to allow me to have a simple extension to provide a bit of overnight charge? Without blowing up the Parents house in the uk or holiday rental in Europe. Because that would be really unfortunate. cheers All. ;-) J
Erm, no, sorry
The car is supplied with a three phase 7.5m Type 2 cable that is rated for up to 32A per phase.
You will need this
only when you need to connect your car to an untethered Type 2 electric vehicle charge point, such as the one you have at home, or those you will come across in carparks at train stations, supermarkets, etc. Lots of fast public charge points have tethered cables (for example Ecotricity points at motorway services) so you don't even need this cable there either.
If you have single chargers installed then you can charge at 32A from a single phase source (7kw, 20mph), or 16A from a 3 phase source (11kw, 30mph).
If you have dual chargers installed then you can charge at 32A from a single phase source (7kw, 20mph) or 32A from a 3 phase source (22kw, 60mph).
If you want to charge your car from something that was not designed to be an electric vehicle charge point (e.g. a UK 3 pin socket, or a European Schuko socket, or industrial "commando" mains sockets) then you will need an entirely different type of cable, which goes by the generic name of a "mobile EVSE" and in the case of Tesla's version is called the Universal Mobile Connector or UMC. These cables all have a Type 2 connector at one end that plugs into your car, a lump in the middle with various bits of electronics and electrical protection equipment inside, and a "normal" mains plug at the other end that goes into the wall outlet. The UMC is relatively unusual in that it has been designed to have multiple different adaptors fitted on to it, enabling it to plug neatly into a 3 pin UK, EU Schuko, 32A blue commando or 16A red commando outlet. When you use the UMC your Type 2 cable is not required. It is about 7m long.
A CHAdeMO charger is something completely different again - it's a Japanese standard for DC rapid charging with a very different type of connector. You will only come across this at rapid public charge points such as at motorway services. Charging from a CHAdeMO charger requires an adaptor from Tesla (£350) but it then bypasses your car's built in chargers, and doesn't use any of your other cables. The speed at which you can charge from a CHAdeMO point (up to 120mph) is not affected by whether you have single or dual chargers in your car.
For maximum convenience people who have untethered home charge points tend to buy themselves a lightweight, short, Type 2 cable to use at home, and leave it plugged permanently into the charge point. This saves the effort of getting the heavy, bulky, Tesla-supplied cable out of the boot every day to charge at home.
