Still faulty car here . Tried 3 different DCDC converters ,3 PTC heaters, 3 different batt heaters and 3 different AC compressors . Also opened the aft HVJB and disconnected DU . Still same F151 and W151 exept when i tried connecting up the last AC Compressor . Faults dissapeared But BMS_f036_SW_HVIL and w036 appeared . Tried all the usual reboot attempts But not willing to start up . Next wil be to lower HV batt and check for moisture/bad contakt . Also remove the speed sensor to se if i have internal leak of cooling water . The DU(no 4) has now 70k miles on it . So probably overdue to internal leakage . Tesla still insists on one of 3 components in the front . There was an change of fault Codes with replacing the last AC Compressor . But still won’t run .
The standard F151 and w151 came back when going back to the old AC comp . And the new F036/w036 dissapeared again . Any idea .
Regards
Terje
