Right. This would make it intentional.The programmer can add code to force a round up for any fraction, but it takes a bit of extra code.
Check displayed charging speed in the mobile app vs what's reported by the API while charging on 120. I actually haven't personally checked in many software revisions, but it was "broken" for about 2 years before which it was correct. It wasn't an averaging problem, you could charge for 10 hours straight and nothing changed, somehow with the API reporting < 4.5 you could get a 5 displayed.
You can't be serious.
- Vehicle DC Wh/mile is measured
- Total (System AC) Wh/mile is measured
- Charge depleting miles are measured
Calculated part is product of 2 times 3 for AC energy into the charger, while product of 1 times 3 for DC energy extracted from the battery
Need the canbus data, but IAM suspect you can find a lot of that percent in the 4kw buffer used to calculate 100%. Also 319 wpm is above EPA rated consumption so you have a small multiplier there to reduce the dash display miles remaining.Great conversation here. Perhaps you can help me solve a question, especially in light of the recent 2019 16.2 update. 2014 P85+ "D" battery. Just drove 182.2 miles. Started with a 100% charge (227 miles rated) Ended with 7% (about 15 miles rated) My question is about the 58.1 kWh consumed. Okay, if the 85 is really 77 kWh, what happened to the rest? The drive was at 319 wh/mi. So not too far out of line. But say this drive used 60.0 kWh total, where did the rest go? I am missing 17 kWh. Has the battery degraded 22%? Before the software update, the rated range was ~255 miles vs. original 265 miles.
I appreciate any insight. Thanks,
Hi, I have 67,000 miles now. I just put 2,100 miles on it the last 10 days. So several sections of 180 mile or so. I don't use rated miles when I drive long distances. It is all bogus. I use percentage of battery and wh/mi. That is what I measure to see if I am on track. That way effects like headwind, cold weather, etc. can all be observed. Yes 319 wh/mi. is higher than the 295 wh/mi. the EPA used to determine rated miles. But either way, in the life of this car, I always keep it between 20% - 90%. My rated miles before the software change was 255. After the software it is now 227 miles. One can say, they just changed the rated miles formula. But that doesn't explain that after the 182 mile trip from full 100% charge, I had used only 58.1 kWh. 7% remained in the battery after 182 miles. I get it that the battery has been degrading. The 85 kWh battery starts with 77 kWh actual available capacity. But a drop from 77 kWh to ~58.1 kWh? Really? I believe this represents the battery capacity limit of the new software. My 85 can barely go 200 real miles.Good info, @supratachophobia, and it would help to know how many miles are on the car, @Blu Zap, as it WILL degrade with mileage. There are a few graphs and charts available but it would be helpful to know your Odometer reading.
That is awful.Hi, I have 67,000 miles now. I just put 2,100 miles on it the last 10 days. So several sections of 180 mile or so. I don't use rated miles when I drive long distances. It is all bogus. I use percentage of battery and wh/mi. That is what I measure to see if I am on track. That way effects like headwind, cold weather, etc. can all be observed. Yes 319 wh/mi. is higher than the 295 wh/mi. the EPA used to determine rated miles. But either way, in the life of this car, I always keep it between 20% - 90%. My rated miles before the software change was 255. After the software it is now 227 miles. One can say, they just changed the rated miles formula. But that doesn't explain that after the 182 mile trip from full 100% charge, I had used only 58.1 kWh. 7% remained in the battery after 182 miles. I get it that the battery has been degrading. The 85 kWh battery starts with 77 kWh actual available capacity. But a drop from 77 kWh to ~58.1 kWh? Really? I believe this represents the battery capacity limit of the new software. My 85 can barely go 200 real miles.
5 Miles degradation to go and you should get a warranty replacement in any case!
Oh oops, you’re right... I remembered (wrongly) that the guarantee in my docs at delivery did mention a threshold of 70%... no idea where that came from, because it indeed states ‘loss of Battery energy or power over time ... is NOT covered.’Based on what? The Model S&X battery warranty specifically excludes degradation.
Oh oops, you’re right... I remembered (wrongly) that the guarantee in my docs at delivery did mention a threshold of 70%... no idea where that came from.
Technically I believe the statement read 'excludes normal battery degradation'.
Not so, interesting read on the 2013 forum:
Battery warranty Model S | Tesla
And as quoted on teslarati:
What Does the Tesla Model S Battery Warranty Cover?
If it's "normal" then it shouldn't need protecting via a recent software update, it would have been known to Tesla for the last 6 years. If you decide to suddenly "protect" something 6 years after you made it, I suspect it's because you found something wrong with it.They might argue that the update was to protect the pack because of "normal" degradation.
I think we are on to something here. it is not a warranty issue. It is a software issue that reduced the range of the vehicles significantly ~15% overnight. That's not "natural" It is the 8 year "unlimited mile" warranty they are concerned about. If they didn't put these range limits on the batteries, something could happen where they would have to do a warranty replacement. That is the mystery issue they are addressing by reducing our range.If it's "normal" then it shouldn't need protecting via a recent software update, it would have been known to Tesla for the last 6 years. If you decide to suddenly "protect" something 6 years after you made it, I suspect it's because you found something wrong with it.
