Bjorn did a couple of tests and got 70 kWh both times (shown in the "Since Last Charge" screen), though he started at 99% and ended at 3% SoC in one and 5% in the other.
I think he could've hit 73kWh if he went all the way to 0% -- come on Bjorn, try again!
This is all making me want to give it a shot myself, hmm...
This is pretty good stuff. Keep in mind that displaying in percentage rounds down to the nearest percent. So, 99% could be 99.999999% or 99.0%... about a 0.7 kWh window. The best way to get accurate measurements would be to put the display in km's for the most granularity. Don't have to leave it that way, just for the start and finish.
Since we have the added granularity, we can see he's at 70.084 kWh in the first video, 70.038 kWh in the second video.
For the first video, starting at 99% and ending at 3% would mean large window of 99.999% to 3.0%, or 72.25 kWh. Smallest window, best case, 99.0% to 3.999%, or 73.77 kWh. I think we can agree his 99% was on the higher end, though, given that the charge stopped there. My guess would be closer to the high end of that 99% window with a very minor pack imbalance causing an early cut off, but no way to really know for sure since he's got it in percent.
For the second video, he was down to 1 kW input power on the charge, with 10 minutes left. So, max of about 0.167 kWh left to put into the pack... probably less, since some of that would be accessories. I'd say he was definitely about to hit 100% within the next couple of minutes, but we'll just round up and say 0.2 kWh away from 100 and add that in to the total to be more than fair. The end of 5% could be between 5.0 and 5.9999%. Would be 74.33 kWh best case, 73.54 kWh worst case, based on those numbers. Pretty close! I'd say the second video probably suffered from the error in the power measurement, though, due to the elevation changes. This system isn't designed to be 99.99% accurate, it just needs to be accurate enough so that you don't get stranded.
The kludge "buffer" code illustrates the margin of error in measurement quite well, with a best case being about a 2.7% margin of error accounted for in measurements based on that. Again, measurements at lower powers have higher error... so changes from uphill to downhill will cross through this high error point often, as will stop and go traffic and such.
Anyway, close, but not quite there.
If someone plans on doing this, I'd say they should charge to 100%, snapshot this with the car set to km's, drive to 0% (or as close as possible, or until you see that 74 show up) on flat roads, avoiding stops, slowdowns, regen, etc.
I'll point out that 74 would still only put total pack capacity at 76 kWh, so 76 is actually the number that would need to be hit to prove the 78 kWh pack claims. I said 74 because that's still basically unattainable without driving through the full buffer, which the car shouldn't allow you to do, but may in some cases.
Good luck.
