It may bear repeating that voltage drop in longer runs may also require larger wire size. Here are a couple of comments regarding automatic charging current reductions that seem to be the result of the software upgrade that detects fluctuations in the input power to the vehicle. (see also Tesla Motors Press Release Jan 10, 2014) Might want to make sure your voltage drop is less than 5% (if this is how the MS senses problems).#8 AWG is fine when THHN/THWN is used in conduit with 75 degree breakers and 75 degree outlets, which are all commonly used today. When you use NM cable, you must use #6.
It took me a few days of testing to catch the car in the act, so to speak. I am charging at a NEMA 14-50 at 40A. Industrial power provided by ComEd in the Chicago area is 208V.
Without load it shows 214V. When charging starts I read between 198V and 201V, it fluctuates a bit. It always takes some time (between 10min and 1 hour) before I get that error message about faulty wiring or use of extension cord and the car reduces charging to 30A. Once it charges at 30A I cannot manually increase to 40A. I have to unplug and reinsert the charging cable. Then I still need to manually increase charging back to 40A until the next "event". Today I was sitting in the car for a full hour waiting for the moment. What happened is that the voltage for a very short moment fluctuated down to 196V. I was watching the screen at that moment and in that split second I got the error messages and the car went down to 30A. So in case of a 208V line and 40A charging it appears that the low limit is set at 196V. Not sure whether it is a faulty line. In fact power provided by ComEd might fluctuate. However, from reading this thread it could also be the charger in the car? What is the email address that people use to contact Tesla to look at the logs? I would like to get in touch with them.
So NEC (national electric code) suggests a maximum drop of 5%. As it happens 197V still rounds to 5% drop, but 196V rounds to a 6% drop. Could be coincidence.
If that were the threshold, I'd assume that on a 240V circuit the cutoff would be at 226V - I have never seen anything nearly as low in my data... but of course it could be very brief fluctuations that trigger this that my logging might have missed (as that samples only once a minute).
Attached as requested. I believe you are correct that this is the side where the majority of the adapter issues have been - this is where my heat problem was, damaging both the adapter and the UMC where it plugs in. The new design seems to prevent bending the retention clip if the button is depressed when inserting the adapter.
Btw, if I try to unplug my HPWC during charge or right after charge, it is impossible to do without burning my hand. I mean the type of burn that leaves redness for several hours. I now have an oven mitt next to the car.
This is incorrect. #8 AWG is good to 50 amps when used at 75 degree rating. If you use type NM cable, which requires you use the 60 degree column, you are correct in that #6 is needed. However, #8 AWG in conduit is just fine for 50A feeding a 14-50 outlet. (NEC table 310.15(B)(16))
How is this true when we are talking about 50A breakers and circuit sizing and the Mobile Connector (or other EVSE) only draws up to 40A? This is the standard 20% de-rating for continuous draw applications, right?The NEMA 14-50 installation for charging is different than any other installation because this circuit will be used continuously at 100% rating of the circuit and typical temperature in garage WILL be above 30º (86ºF) during summer for at least half of the US...
Think of it this way: A continuous load must be used on a circuit rated to at least 125% of the continuous load.How is this true when we are talking about 50A breakers and circuit sizing and the Mobile Connector (or other EVSE) only draws up to 40A? This is the standard 20% de-rating for continuous draw applications, right?
Your electrician installed wire insufficient for the application and not to code.I'm interested because I just had a house built in 2012 and the electrical contractor put "E123775 8/3 W/G TYPE NM-B 600V (UL)" in the wall without conduit for my two 14-50's. This is Red/White/Black insulated 7 strand copper with a solid bare ground wire with the 4 wires sheathed in black plastic. I have since changed one of the 14-50's to a 6-50 for use with my Leviton EVB40 40A EVSE.
That's dangerous advice. A plug that is so hot that it burns a person, should not be used. It could still be dangerous at 60 amps. It is dangerous to use electrical equipment with known safety faults.I suggest lowering your charge rate to 60A until you get a ranger over to check this out. This is not normal HPWC behavior.Btw, if I try to unplug my HPWC during charge or right after charge, it is impossible to do without burning my hand. I mean the type of burn that leaves redness for several hours. I now have an oven mitt next to the car.
In order to eliminate confusion I would suggest that you either remove or modify all your posts that include blanket statement that it is ok to use #8AWG for NEMA 14-50 installation
While Leviton NEMA 14-50 outlet which I linked in my previous post indeed is rated for use with 75 ºC conductors, this is not true for all equipment.
I find this discussion both educational and fascinating. One takeaway I have is that given the disagreements amongst experts, the reality of thousands of installs is that someone is bound to get it wrong. Maybe a TMC handbook on what to ask the electrician, how to verify that the electrician did proper work, and basic safety tips. Like not putting newspaper near the outlet. I'm sure quite a few installs are not inspected, especially 14-50's.
Please note, that as I've posted in #106 above Tesla did add requirement on sizing conductors for NEMA 14-50 install to their installation sheet, it is now explicitly states that the recommended conductor size is #6 AWG. The Falsher's opinion is not just different than mine, at this point it is direct contradiction to the recommendation put out by Tesla.
Circuit installation should meet National Electric Code (NEC) wire and breaker ratings. In general, this means 6 AWG wire for installations under 100 feet
Indeed, which is why the FAQ exists.
My local inspector insisted that, as part of my install, the it wasn't sufficient to have just a sub panel in the garage. I had to get a service disconnect near my other panels so that there was one place in the house to turn off all the circuits. Prudent, but it cost me about another $300.
In my uncooled/unheated garage, even when it is 40 degrees C outside, the internal temperature does not justify ambient temperature correction. I live roughly at the midpoint of the US population.
Guys, this is a moot argument, as no competent electrician is going to recommend, and install #8 wire for a 50A outlet that will be used for continuously charging an EV. The difference in copper cost is so little, that you will make up for it in less than a years resistance loss on your electric bill. Using #8 for a 50A EV outlet is just stupid. It's tripping over dollars to pick up pennies.I can appreciate that you really, really want to be right. Tesla says specifically that circuit installation should meet NEC wire and breaker ratings. The NEC says that #8 wire in conduit does conform to the code for a 40A continuous load. Bottom line, Tesla defers to the NEC. Tesla notes in addition that generally, it means 6 AWG wire -- but we don't know their assumptions for "generally". In my experience, this is because the average installation uses NM cable, which would require 6 AWG. It is not "direct contradiction".
To avoid this from being taken off track any further, I won't respond any more to this argument.
The summary is this:
1. It is perfectly legal by NEC standards to connect a 14-50 intended for a 40A continuous load with #8 AWG wire in conduit (subject to conduit fill requirements, current-carrying conductor requirements, et al); it is not legal to use #8 NM-B cable.
2. The super-technical interpretation of the NEC suggesting derating for ambient temperatures in a typical garage does not square with experience in the field.
3. Most electricians will run #6 anyway, to give some headroom and to keep the number of cable spools on the truck to a minimum. I recommend the same and my own installation uses #6 in conduit, but I would never force someone to rip out #8 if installed properly in conduit.
4. The AHJ serving your jurisdiction is the authority -- ask him or have your electrician do so.
The last point is the most important. A good Internet forum rule is that you don't have to trust me and you shouldn't solely rely upon my recommendations, because you and the AHJ are the two most important people in this installation.
My garage routinely goes to 55 C in summer during the afternoon, so I did calculate the derating when installing the wiring (some 3 years ago now). However, at 4 am in the morning (when charging), the temperature is always below 30 C.
I went with 6 AWG, mostly for wanting 48 A continuous, and, as I recall, 2 pair of 6 AWG is the max you can put inside 3/4 " EMT.
Yes, it's legal per the NEC, and most RV parks use #8, especially the older installations. I ran the calculations when I had my outlet installed, and the cost difference came out to less than $20 difference in materials to run #6 in 1 inch conduit. Since I will be using this outlet for many years, it was a no brainer.I agree that most electricians are going to use #6. I recommend the same. What I said is that a #8 installation is perfectly legal (for example, if you had an RV outlet already in that location) and that I wouldn't rip out an installation done with #8 if your goal is a cheap install. I have seen a number of RV outlets fed with #8, and there's nothing wrong with them.
Just curious - what's the outside ambient air temp when your garage goes to 55 deg C (130 deg F)? What's the factor that drives it up -- do you have heavy use of glass?
In your case, I would say that you should adjust for those factors, although I suspect the AHJ wouldn't even consider it during the inspection.
