View attachment 260232 View attachment 260233 View attachment 260234 The Power Magic Pro is not recommended (by other owners that have installed the Blackvues) for Tesla's. We simply don't need it. The Blackvue is not going to draw enough current to run down your 12V battery. Skip it. Hardwire kit? Its up to you. But in my opinion and my experience, its overkill. Here's what will work and is easier.
- Blackvue Power Pigtail 1.3mm x 3.5mm x 11.2mm Plug with 6 feet Cord Electronics
https://www.amazon.com/gp/product/B000LFRT8K?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
I don't use the cam-cam cable that comes with the kit either. Its about 10 feet longer than needed. I used the 20 foot version bought separately. Besides, not unfurling the power cable and cam cable in the box allows me to offer it untouched later when I sell the dashcam used on eBay. Here's what I use.
- Blackvue Pittsoft Blackvue DRxxW-2CH To Rear Camera 6M (20FT) Connection Coax Cable
https://www.amazon.com/gp/product/B01I2AMDSQ/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
And if you are as anal about making the perfect connection in the car for power, here's links to the OEM male connector and the pins used inside.
- Dashcam Mouser Connector Housing Male 3-968696-2
3-968696-2 TE Connectivity | Mouser
- Dashcam Mouser Connector Terminal-Pin Male 928918-1
928918-1 TE Connectivity / AMP | Mouser
This is the pigtails that I use for 12v connections on puddle lights, logo lights and my dashcam to make it quick and easy to connect devices. These have a clip that prevents them from pulling apart. And they are very cheap.
https://www.amazon.com/gp/product/B06WGN56V2/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Here's a picture of the OEM connector (housing) that you use in the mic grille for power.
I added two wire pigtails to the connector/pins to make it easier to manage once installed. What you don't see here is the inline fuse that I added between the power and the 1.3mm pigtail. See below for a picture of the fuse harness.
