phxazcraig
I didn't hear it at normal volumes, but I don't doubt you. Here's what I would try to isolate things.Apologies about the audio everyone, headphones if you can and you should be able to hear it! regardless, im not dreaming it all as Tesla has tried remedying the situation to no avail! really interested to see if anyone else has had this persistent problem. thanks for the responses so far!
First - is it wind noise, or is it something inside the build of the car rattling in some way? Wind noise should at least change with speed - different pitch, get louder, etc. If it is some mechanically-caused noise (maybe something with a window motor), it won't change sound with speed, probably.
My guess, along with everyone else's basically, is wind noise. (Again, I couldn't hear anything so speculating based on your description.) I've had speed-induced wind noise before on cars after a windshield replacement, and I tracked it down to an edge condition. At one or more spots along the windshield edge, there were gaps and/or an edge sticking up or down, and that was the spot the wind whistled. (By the way, does anything change if a window is cracked a bit? Probably too hard to hear.) Anyway, the idea of using blue painter tape is a good one. Cover all the edges of both doors and windows on the driver's side, and get in through the passenger side.
I thought about the idea of using a directional microphone to isolate the sounds. Such things exist. In a similar thread on Reddit, I found this interesting answer to a similar question about tracking down an annoying sound: "Get a cheap directional mic that plugs into an iPhone and use app ExtraEars to locate it. It's a spectrum analyzer which is what you're going to want. A deity v.mic would probably work." That basic concept sounds do-able.
