This should have a seperate thread. I believe this is the most logical answer I've heard. Think about these applications of a "trickle charger" mounted in the frunk cubby.
*No more Brodering. You always have spare power with you if you run into bad weather or detours. Worse case, you have to pull over for a while to charge up enough.
*You get home late with little charge only to discover power outage at home. No problem, you let the Air Metal run while you sleep and you have a charged up car in the morning.
*You go to the lake to fish. No power outlet, no problem again. Camp all weekend and drive back on a full charge.
*Extended distance travel. Turn on the Air Metal once the battery is down 10% and trickle charge as you drive. Can't do this with an ICE!
What I like about this solution:
You don't need swapping stations. You would simply go to existing service centers or have a Ranger come install it. It would be rated on "hours of charge", not how many miles you could drive. Software would keep track and you would know when it's time to replace. Because it's not designed to put out enough power to "drive" the car, it can be light enough to not cause weight or storage issues.
@ jefffadams and @ alpha
A add-on battery in the frunk seems to be the most logical idea. It has many advantages in addition to the one you already highlighted
- Tesla's approach to problem-solving is a very simplistic. They will not propose anything which makes the whole thing complex and then adds cost. The longer and complex the battery swapping is, the costlier it becomes. Just imagine lots of people waiting for battery swap, more people leads to more infrastructure and again hidden costs.
- People will have ownership of their battery. The whole idea of swapping with someone else's battery will not take hold. As mentioned in the post. The only way it can work is that used batteries will be swapped to the next vehicle, to keep inventories low and decrease costs related to storage. If your batteries are swapped then there is no point in owning battery and Tesla will need to refund current owners.
- If Tesla decides on main battery pack swap then leasing is the only way to go. It can make Model S even more affordable. Now how to please people who bought the battery pack, no leasing costs and no swapping costs. Charge others who lease the battery, lets say 2000 $/year for 60 kWh and 4000 $/year 85 kWh for a 6 year lease. This way you can have lower upfront costs and be flexible if life situation changes. Just agree to higher battery lease if you move and 60 kWh doesnt suit you. I still think swapping main battery is a cumbersome an unlikely idea, I like my odds with a frunk add-on.
- There is another post on forums,where owners have discussed how quickly the pack can be changed. It seems it is quite an extensive operation taking certainly more than 15 minutes, even if it is automated the time to mount the car needs to be factored in, as the cost of installing robotic machine. The add-on battery is just put in the frunk and you drive away. How easy would that be.
- They need to offer this solution to every Model S owner, irrespective of current battery size. Storing different capacity packs will again lead to increase in inventory. How about one size fits all add-on battery? No matter what your current capacity is, come and have the add-on installed and drive away. This will ensure that 85 kWh don't feel cheated by 60 kWh owners getting 85 kWh in swapping.
- They can have these add-on battery charged overnight, esp when electric rates are lower and they will be ready to go. These can be charged by solar too. Elon owns solar-city and deploying more solar panels to charge add-on batteries can only be good for that company. I think it is brilliant to use your current company to jumpstart your next big thing.
- Tesla needs to be sure, which battery tech is for future. There is lot of noise in battery tech and everyday you hear that some new battery tech will give these many miles. Point is, that battery tech is still very young and in rapid R&D phase. It would be foolish to bet big on any tech at this time and integrating that tech in large battery packs for swapping. Take the next tech, have it ready for smaller add-on packs and you can test the tech in the field. If something better comes along, then use that technology in add-on packs. This way Tesla can test many different techs at the same-time without actually integrating it in large battery packs.
- Tesla owners need freedom to roam anywhere. The battery needs to be such that it can be swapped at any service center. Somebody gave a good analogy with red-box. That's exactly the approach Tesla needs. Pick up a battery at one service station, keep it as long as you need it, return to any service center on your way. Your original battery is always on your car, no need to go back to the same service station to get your pack back.
- How should they charge? There has to be an uniform fee structure without any significant difference between 60 kWh and 85 kWh owners. Both should be equally eligible for such facility. The new gen add-on batteries will be expensive, so you only lease it for a minimum charge. Tesla can charge for the juice in the pack, free to them if they use solar to charge. Basically, the application needs to be widespread and still cheaper than buying a tank full off gas (lease cost + charge costs) for it to succeed.
- This can also earn extra revenues for the company, as supercharging is free. However offering add-on packs will reduce congestion on superchargers and will reward drivers who are willing to wait a bit, but still offer convenience to drivers who are in hurry. Ultimately everybody wins.
Hope you all like the reason. Feel free to comment. Waiting for all announcements to be over quickly. The suspense is toomuch to take.
