I think there is some sort of slow charging issue at the Port Orange, FL Supercharger. We drove our Model X up from Miami to NY in mid-June and back to Miami this week. On the way up and down, I experienced terrible charging speeds and voltage at Port Orange. I reported it to Tesla by calling the 800 number in June and once again yesterday. At no other station from Miami to NY was there consistently poor charging speed like in Port Orange.
I arrived yesterday with 3 miles in the tank and tried every single station to see if there was one good stall, but the fastest any of them charged in 1 hour and 20 minutes was 61kW. I was the only one charging there each time I visited.
If someone has any pull with Tesla (@Larry Chanin ?) would you please point out this huge gap in the I-95 corridor in Central Florida? In a Model X P90D, which only gets about 200 miles of realistic range at highway speed, St. Augustine isn't reachable from Port St. Lucie unless you stop in Port Orange.
Location is great....
if you continue past the chuckie cheese, through the plaza there are public restrooms.Where do you run to the bathroom when ChuckyCheeses is closed?
Follow the water side as you pass Chuck E. Cheese and the rest rooms will be directly ahead of you, almost always empty and clean.Where do you run to the bathroom when ChuckyCheeses is closed?
I stopped there last week, and I think on 1A I got about 30kW, and then moved to the other end and got 60kW. So something is degraded there.
I've seen issues with Sc in FL & Ga and found Port Orange slow June '16 but "With only 3 miles in the tank" your vehicle would naturally slow charge. It's been reported to me by Tesla (and there are several blogs about it) that anything less 10% can lead to slow charging. At three miles you were definitely throttled.
Thanks @X Fan but im talking about the entire visit and not just at the start of the charging session. I've been to 56 Superchargers according to TezLab. Throttling until 10% is to be expected. I've also had discussions with Tesla about why the Model X rate of charge is restricted at its peak to about 75-80% of full capacity since I thought our X had problems when compared to our old Model S supercharging speed.
If you arrive at any Supercharger with only 3 miles in the tank, you will get a pretty slow initial charge, until your battery gets up to about 10%. Then it will charge faster untill you get to around 90%, then it will also slow down to fully top off the charge.
Batteries charge fastest between 20-80%
Did either of you call Tesla support to report these issues? They won't be fixed unless someone reports it.
I'd venture to guess they can pull logs on your charging sessions to confirm your issues.
