I wouldn't say that -- I, for one, definitely cracked a smile!Right, and by hilarious, I meant not at all funny........
Fargo has 8 installed. Only four currently on. The same thing in Miles City. They’ll turn them all on after a little while.Interesting.... and maybe mentioned before.... that they only put in 4 chargers. I mean it's a major N/S, E/W intersection of Interstate SpC routes. The rest of the ND locations have 6 or more. I mean, worst case - there are chargers in five directions, what if Alexandria, Baxter, and Clearwater, Minnesota, (8 stalls each) and Sioux Falls, SD (also 8 stalls), and James Town, plus Grand Forks, ND (which have 8 and 6 stalls) all have Teslas finish at the same time and head to Fargo which only has 4?
That's 46 cars needing charge at a 4 stall location.
Fargo needs more chargers STAT!!!!
This has been the pattern of many of the v3 installations.Fargo has 8 installed. Only four currently on. The same thing in Miles City. They’ll turn them all on after a little while.
Ahhh.... so that should handle the 46 incoming cars.
I understand Tesla's quandary about SpC planning and actual implementation. But hopefully they are planning to double or triple up these intersecting SpC routes at crucial points.
One tricky but unlikely solution would be to vary the charging rate real life so that groups of cars are not leaving (and thus arriving) the SpC's at the same time. (Of course a programmed variation of speed thru Autopilot could also assist in arrival differences). So, yes, they can control the world!!! Mwaa Haa Haa !!!
I think another point - especially in summer - is that the charge points are far enough apart that the typical vehicle stop does not need to be to full charge, or some vehicles could leapfrog every other charger. It's not a matter of every vehicle spending almost an hour at every charger on a cross country trip.
Fargo to Jamestown is 90mi for example; at over 600mph charge, the battery should be recharged in less than 10 minutes. I usually spend longer than that parked at a gas pump for a pit stop with my ICE vehicle.
When we are travelling again, I guess I'll see how EV travel compares.
Unless of course your car is Supercharged limited and can max out at a measly 64kW at 35% SOC. There are still quite a few of us that have these relics. With the battery capping factored in, a 90-mile jaunt at interstate speeds would need about 130 miles of real-world range, or about 60% SOC.
Also, it's not as if everyone charging in Alexandria, Jamestown, Winnipeg, and Sioux Falls are all on their way to Fargo.Tesla has essentially installed its basic build, which is 8-stall Superchargers spaced to allow year-round travel.
The capacity is currently in excess of demand.
The density is not optimized.
Tesla will react to any future demand growth by adding stalls in existing, nearby or additional locations to increase density, capacity or both.
Exactly. This scenario is absurd.
Sorry, my career was with NASA. Preparing for 'worst case' is ingrained. But actually planning (due to costs) was for 'most likely bad to worst case'.
