There are two types of dryer receptacles, 10-30 and 14-30, depending upon when your home was built. There are some Tesla adapters available for the UMC plugging into these receptacles, but you noted 20 feet which is beyond the 18 ft of the UMC. Your best bet, for emergency use only, is to create an emergency cable, about 6 feet long, appropriately wired and labeled "for emergency Tesla charging only" (or purchase from a place like EVSE adapters). See my FAQ for more details.
As for what you could run with the Model S charging, a 22 kW genset can run about 90A of load. With Model S charging at the full 24A off a 30A dryer receptacle (the continuous limit of that receptacle), you'd still have quite a bit of room for other loads - certainly your A/C and many other appliances.
- - - Updated - - -
Some inverter generators won't work, depending upon how their grounding is set up. If it's a "floating neutral" generator, the Tesla UMC will flash red four times because ground won't be stable relative to the line voltage. Some generators can use a special plug to bond ground to neutral to make it work, but in others it will not work (and will destroy the generator).
