Yes but that is assuming that You want to get all of it back...
How can you get energy back from a motor in regen when the car is already in motion? a portion of the energy is sent back to the battery...how's that possible when that same battery was powering that motor in the first place...? At that moment you may argue that the battery stop sending energy entirely and then regen is possible...
Let say you had a motor that was never connected to the wheel and was solely use as a generator...and lets say with a gear system (meaning not using chemical energy or electrical energy) but straight mechanical energy that is already happening at the wheels turning So basically if your motor was efficient enough to work as a generator and let say a 2000RPM would give you X amount of kwh...i'm not claiming that It will be endless free energy lol, but what I am saying is if the car was rated at 200miles that configuration would help increased its range and maybe it would be 500 miles...
Because in theory, you would have a constant state of regen (at 60 mph) that would take it longer for the overall energy from the battery to be depleted...
So to use the water analogy, Let's say the battery was a 100 Gallon tank and there is a valve (pedal) and when open the valve (push pedal) you are dumping that water into the ground...So rate of flow would be how much you open that valve (or push that pedal to the floor or not...) so the way I understand regen so far is your kind of connecting a small tank of lets say 20 or 30 gallons that store the water when you use 100 gallons of energy and you have regen you end up using an 80 gallons and have an extra 20 gallons of water to keep going...
So if I can have a motor efficient enough to allow me to store that 30 gallons of water all the time (at a certain speed), while the other motor drives the car then eventually the 100 gallons will be depleted but 1st it would take longer to deplete because in that same time I end up using 70 gallons, and when I can not use anymore I still have that extra 30 gallons In the current tesla models regen allowed that 100 gallons to be depleted in lets say 10 min...than the system I had in mind would be maybe 20 minutes...
It's a really rough example, its hard for me to convert what I have in minds in words, and then again I am not saying that it's not stupid because that efficient motor would still have to be designed, and there are also other things I know I am missing...I need to spend more time and research more about regen...but basically I just don't see it as impossible...then again that's using the laws that we currently understand...there are probably others laws that we haven't fully explore lol ...
Basically, the range extender works on the volts because there is 2 source of energy...2 separates tank plus the smaller regen tank...1 tank has electrical energy, the other has chemical/mechanical energy...
my system I would have 1 tank for electrical energy + a smaller tank for regen...but the other source of energy would be mechanical energy generate from the motion...all it takes is spinning wheel and the proper gear ratio to have the energy that you want...and that can be done now
But I don't regret making that page...somehow the different point of view I've read help me out...but I've said enough lol time to do the work and fail 1000 times before i get it right #motivation lool
I guess we should talk about
regen in general and
how one motor can send power to the battery, while another gets powered by the battery.
Regen first: There is no such thing as a generator or a motor setup with electric motors, they can be used as generators, e.g. for regenerative breaking, as effectively as for motor applications. Thats why they actually are electric machines, not motors. And its not a matter of turning it the other way to regen. It an both apply power when driving forwards, as well as backwards and regenerating forwards and backwards.
With the
induction motors Tesla is using, its just a matter of the frequency of the magnetic field and the frequency of the rotor. An electric machine consist of two parts, the
stator, which is stationary and the
rotor, which moves and is connected to something that needs to be driven, in our case the wheels(with some detours through the gearbox etc.). The
stator has windings and through those windings flows an AC current. In fact its 3 different AC currents with different phases. Those windings produce a magnetic field that moves around the inner side of the stator and flows through the rotor. The rotor consists of very solid "windings", it looks more like a cage filled with sheet metal, and if the magnetic field is faster than the rotor, it induces a voltage that causes a current, which in turn makes the rotor move. Thats the source of the torque. If the rotor moves faster it induces a higher voltage to the stator windings and there is current flowing back, through the inverter, into the battery. (The inverters job is it, to modulate a three phase AC current, out of a DC current, and the other way around.)
Now, how can one motor power the wheels while another puts power into the battery? Lets go back to our water example. Imagine two bathtubs, both half full with water. The first should be the battery chemical energy, the second is the cars kinetic energy. Now you grab a bucket and start moving water from tub one(battery) to tub two(kinetic energy), so you are the motor. I will do the opposite, I grab a bucket and start filling tub one with the water from tub two. I am the generator. On the way we loose some of the water, we aren't 100% effective, but that water is lost, it would be heat, we can't really get it back. Someone interested in thermodynamics would call it entropy.
Now here is your problem, neither you nor I, motor and generator, really store energy/water. Or just for a really short time. A motor/generator can only move energy/water from one form/tub to another. So to make your car go further with the same battery, you either limit the conversion losses, make your motor/generator more effective, or you limit your losses through drag. Drag is something like a hole our kinetic energy tub.
You could also make the battery tub bigger, so it can store more water/energy. Or you get a third tub, a gas tank, and fill your battery with the energy out of that petrol. Like the Volt or the i3 rex. But for that tub you need a special bucket, in fact two buckets, an electric machine and a internal combustion engine, and the second bucket looses about two thirds of its water on the way, which isn't really nice.
