Bring it back.I just got an alignment done today at Eurofed for my M3LR. While driving to work, I noticed that my steering wheel is crooked. Could it be that the alignment was not done properly or something is wrong with the steering wheel itself?
Note there is a software offset correction. Make sure your alignment place is aware of this. It may be the source of your problem if the alignment was done correctly. I have also read it self corrects (before service mode was possible).I just got an alignment done today at Eurofed for my M3LR. While driving to work, I noticed that my steering wheel is crooked. Could it be that the alignment was not done properly or something is wrong with the steering wheel itself?
Yes, I called them and told them what happen. They say I could bring the car back inBring it back.
The procedure to aligning the car involves centering the steering wheel, locking it in place so it is completely centered, then measuring and adjusting the tie rod ends (this is the step that actually adjusts where the front wheels point).
What happened was they either didn't center the steering wheel, or they didn't (or didn't know how) lock it in place so it stays centered.
With service mode now available to users, yes you can now do it yourself. Previously the system self learned, but that may take a while. But probably your alignment place should help you get everything correct as this might not be the issue.I didn't even know about this! Thanks for showing the video. If the alignment was done correctly, is this something I can just do myself?
The software adjustment however makes the car do active compensation, meaning it actually physically moves the wheel to adjust for the set offset. This has caused cars that had a centered alignment continually get off center again until the offset is cleared. It's not something that is completely passive, so it can cause the wheel to actually move off center while driving. It can really trip people up if they are not aware there is an active software correction mechanism.I would assume this is just a recalibration of the angle sensor though and that it would not affect steering wheel position. Steering wheel centering is a physical link between the steering column shaft and the wheels through the steering rack. They are hard parts that need to be set correctly to ensure a straight steering wheel position with proper toe settings.
Ok, I'm going to take a look into it when I get home. I'd rather not take it back to the alignment shop if I can fix the issue on my own since it's a 1-hour drive from my house.With service mode now available to users, yes you can now do it yourself. Previously the system self learned, but that may take a while. But probably your alignment place should help you get everything correct as this might not be the issue.
No you'll want to bring it back unfortunately. The software compensation is for autopilot to learn how far to turn the wheel for it to go straight.Ok, I'm going to take a look into it when I get home. I'd rather not take it back to the alignment shop if I can fix the issue on my own since it's a 1-hour drive from my house.
Thank you, everyone, for your input! I really appreciated it.
And yet the Tesla service center I that did my 4 wheel alignment 3 times, still couldn't get my steering wheel centered. So is it possible that this service center didn't do the procedure in the video? I'd think they would have known about it.
Correct! The only way software could center the wheel would be if there was no physical connection between the steering wheel and the steering rack.No you'll want to bring it back unfortunately. The software compensation is for autopilot to learn how far to turn the wheel for it to go straight.
What you described with the steering not centered while the car physically is going straight means you need to get this PHYSICALLY changed via adjusting tie rods, it's not a software issue.
Do go into service mode and do a reset after you get the steering wheel centered though.
I live in the US, but I think the principle still applies. Teslas are looked upon as a performance automobile. Even though I had no uneven wear, I took my Model Y to a performance race car shop. These shops service the needs of track and street, factory race cars. The alignment was perfect; perfectly centered wheel (was slightly off from factory) and NO pull right or left. Much better than factory setting. I paid $265.00. Maybe you can happen upon a shop like this in the UK. Cheers.I just got an alignment done today at Eurofed for my M3LR. While driving to work, I noticed that my steering wheel is crooked. Could it be that the alignment was not done properly or something is wrong with the steering wheel itself?
Similar story here. I had a Pontiac G8 GT that the dealer could not get properly aligned after three attempts. I took it to a performance oriented tire/suspension shop 60 miles away. The owner said "Don't worry, this guy makes 'em go straight down the road". And he did!I live in the US, but I think the principle still applies. Teslas are looked upon as a performance automobile. Even though I had no uneven wear, I took my Model Y to a performance race car shop. These shops service the needs of track and street, factory race cars. The alignment was perfect; perfectly centered wheel (was slightly off from factory) and NO pull right or left. Much better than factory setting. I paid $265.00. Maybe you can happen upon a shop like this in the UK. Cheers.
