Merrill
Merrill
I have not seen anything over 100kW and 250miles per hour anywhere I have charged in over a year.
Yes, thanks I forgot about that. Still very really get close to 95.I don't think the 75 models charge over 100 kW. They charge max 95 kW IIRC.
Anybody seem to know the reasoning why the stalls bounce up and down from 0 to xx amount when there are issues? I know Burbank has it's fair share of troubles all the time and just had another 2 stalls down hard.
Was curious if anybody has talked to the SpC techs on why this happens?
Wdolson,
I experienced the dread reduced rates in Manteca and also at Corning in late September. I telephoned Tesla. I clearly explained that I was the only car present. I explained that my initial rate was ~115kWh, but within two minutes plummeted to around 58 before stabilizing at 72. The employee was nice, but seemed unconcerned about the situation. He seemingly read from a list of canned answers: (1) Find an unpaired stall because the second to plug in receives a lower charge at the beginning. [Were you even listening to me, Tesla employee?] (2) Try another stall. He screen indicated that I could choose from any of the remaining seven. [How does this reconcile with your previous statement?]
I merely wanted the representative to communicate to the correct department that the charge rates were about 60% of ideal. He seemed reluctant or unable to pass along the information.
Since I did not feel like this was important enough for their representatives, I do not wish to waste my time and punch buttons on my phone and wait on hold to report something like this. It seemed to me to be an exercise in futility.
I would think a lot of owners pay attention to charge times. If you have a schedule and can't make it because the charge rates are so slow at certain locations, complaints are certainly valid. At some point inconvenience trumps the coolness of driving a tesla.... I hope they figure this out before the 3's are all out there... I know they are working on it, lets hope they solve it. If wait times increase significantly I would reconsider use for long trips in highly populated areas... but I didn't drink the koolaidWhat false advertising??? I think you're being overly dramatic about something that the vast majority of owners wouldn't even notice... Case in point, last long trip we took I can think of only one time where I even thought about the rate of charge and that was at SJC after we got back from starbucks when I noticed I hadn't gained enough range to make it to the next stop when I "should" have...
Someone else correct me if I'm wrong but I don't think many owners are paying that much attention to just how "fast" they are charging when at a SC stop... What I think most of us care about is whether or not the car is ready to leave when we are, if it is, then how fast it charged to get there doesn't matter... Only if it isn't does anyone start to look for "why"...
Jeff
@apacheguy I asked my service technician at the Houston service center what is the story with colder temp charging. He said that the battery, itself, limits charge coming in below 55ºF... until the battery warms further. He said the battery is happy when temps are higher, even into the 90ºs. So, I'm supposing this limiting you observed occurs on the SuperCharger side of the combined car+charger. Is there a pattern to what you've seen? And can that pattern be isolated from the possibility that you just pulled up to a charger that was 'warmed' by somebody who left 5 minutes ago? I'm looking for a rule-of-thumb. As in, "Charging at temps over 85ºF ambient will force tapering sooner"
The limiting/throttling/USPR is absolutely not related to pack temperature. As you can see, my battery temp was consistently increasing throughout the charge session, yet I was able to restore normal charging amperage by cooling the connector and cable. Also, note that no other Tesla connected to any stall at the site for the duration of the data collection.
Additionally, I noticed that in lieu of cooling the cable you can simply switch stalls from A to B (on the same cabinet) and this will restore a normal charge rate. So, it has nothing to do with the car, it has nothing to do with the cabinet overheating, and it has everything to do with the temperature of the cable/connector from the pedestal.
Bottom line: Yeah, this sucks. I mean, SpC used to be a set and forget experience. Plug the cable into an unpaired stall and walk away. Now, it appears that Tesla Engineering has tightened the thermal limits and aggressively tapers the charge rate if they see the connector getting too warm. While I appreciate the reasons for this, it significantly degrades the user experience and I urge Tesla to come up with another solution. (What happened to liquid cooled cables???)
Unfortunately, the workaround for this means that you must stay with your car the entire time and be ready to act in case the rate begins to decline at a rapid rate. I witnessed this behavior ~50% of the time. Sometimes supercharging works great, but in others not so well.
I had this happen at the BRAND NEW supercharger at Anderson's Split Pea. So even new equipment is no guarantee that this will not occur.
Yikes! Good advice, as I'm likely to do something like that in next 2 weeks. Instead, I'm going to charge overnight to 92%, and then ~90 minutes before departure, remotely trigger continued charging on hotel HPWC (double whammy, expecting <50º temps and well into taper).... park[ed] the car at a hotel overnight and temps get below 50 F ... The one time I did this, it took over 25 min to reach a normal rate. I'll never do that again.
Sometimes what appears to be a single issue can have multiple explanations. Life is often more complicated than it appears...It has nothing to do with cold temps. In fact it is too much heat (on the connector handle, not the main battery) that has caused the limiting I observe. See a few pages back for my analysis. Here:
