C141medic
The resin does a pretty good job of filling the chip. You have to follow the instructions closely though to get a proper repair. Depending on the size of the chip, you may still see it a bit but definitely to a lesser degree than what it was because the resin fills in the damaged areas. Like I mentioned, for $10 it’s well worth it. Otherwise, you can go to Safelite or another auto glass repair and pay anything from $50 and up. Alternatively, if you have comprehensive coverage that also covers glass repair with a zero deductible, you can look into that option as well.Ok, thanks! One more question. Do you know if the dent will still be visible even after fixing it? Does fixing it restore the dented part to its original form?
