Thoughts:
1. St Lawrence is King - 348 units average flow vs 265 for Columbia River.
2. 'What if your Inverter breaks?' - Radian Inverters are 4kw each and scalable so use as many as you need, usually a minimum of 2.
3. 'Only 48 volts' (someone said). 48v is a *big* improvement over 12v which requires HUGE cables. Going to 96v would introduce much more of a shock hazard.
4. Wk057 has configured his salvage MS battery to run at 48v. The rest of us not so lucky to have such a huge bu battery can use ICE genset to reduce the size requirements of battery bank. Ideally the genset running on nat gas [city piping] or propane adapted carburetor. These dry fuels are very kind to ICEs and save you from having to deal with dangerous gasoline storage. Can tie genset into propane tank that runs kitchen stove, for example. Those that can reduce their nighttime electric usage significantly should be able to get by using the smallest battery bank possible. [research needed].
5. My setup will retain existing grid tie and min monthly payments to pay fair share to maintain grid infrastructure, among other reasons. I plan on switches to run as much as possible off the solar panels. BUT the solar setup will not be grid-tied since use of the logic plate will require that the main breaker be OFF before solar/genset can feed into the main panel. A 'dual either/or' system? Is there a name for this?
