So I just changed back to my Summers, the Stock OEM 20’s with the PS4’s. Upon doing the swap when I pulled off the winters I noticed on all 4 3mm hub lips rust around the circumference where it mates to the rim. Couple of Q’s.
Are any of you guys seeing this rust as well after the winter to summer swap? Is this rust on these hubs a normal occurrence? What are you using or are you using any type of rust preventer like T9 or Stabil Rust Preventer? Is this even an issue and will it be an issue over time? Car is only 8 months old. Obviously just concerned about the rust getting worse over time and eating the steel hub and or inner rim ring. Would have grabbed a few shots but was pressed for time.
Appreciate any input, experiences and/or advice on what you guys are seeing and doing if any.
Ski
Ski
