Has anyone figured out any options to reduce brake drag?
I have an M3P that I track a fair amount. I'm on my 3rd set of brake pads at under 18K miles.
The car also uses about 330-350wh/mi at 65 MPH on flat ground. I've driven identical routes with other M3P's and the car uses a lot more energy. I do have 265 tires on the car, but that's not enough to increase drag by 40-50%.
I recently was thinking about brake drag, and apparently Tesla does use a special caliper boot to retract the pads more than other cars to minimize drag. @MountainPass says that these tend to wear out when used in anger:
So I'd like to try to reduce brake drag on my car, and see if this is the source of high energy use. Tesla doesn't sell replacement brake hardware, so I can't try replacing the boots. Other car manufacturers that have focused on low drag have used springs which separate the pads some, and there are even aftermarket ones for some cars like the Insight.
Anyone ever tried anything or have any good ideas on how to push the pads out just a very small amount when not braking?
So I went out to my car, took a wheel off and spun the rotor. Didn't seem like much drag to me, but it's hard to tell with the AWD system. Then I knocked back the pads just a touch with a screwdriver until I could just barely see an air gap between the rotor and pad- and WOW, the rotor was way easier to turn. There was also no brake noise present that is otherwise present on all 4 corners of the car.We also learned that the low-drag seals that help make the Model 3 so efficient lose their effectiveness after a few track days, as they are cooked and no longer seem to have the same kind of effectiveness as when they were new.
