Hi All,
I've only had my Roadster about a month now and I'm all ready thinking about "personalizing" it...I can never leave "well enough" alone.
So in the interest of reducing the understeer and the lack of OEM sized rubber, I have been thinking about new/different wheels. As has been noted in previous threads, the PCD on the Roadster is not very common. I have been considering putting the rears (17x7.5) in the front and running 205/40 tires which would have the exact same overall diameter (23.5") as the OEM 175/55-16. Without any spacers, this setup would extend out about 6mm further from the car than stock. From what I've calculated, others have put on aftermarket wheels that extended out 15mm w/o any problems. But, again w/o spacers, the inner edge would extend toward the car 32mm. I've read that another, had a different aftermarket wheel that extended inward 27mm again w/o any issues. So, has anyone tried the rears on the front? Any thoughts?
As for the rears...I have found a 17x8 wheel that is very similar to the OEM wheels. It is a straight eight spoke design (no twist), 65.1 CB, 5x110 PCD, and 30mm offset. I think a 245/40 would work just about perfect...the overall diameter would be 24.7 as compared to the stock of 24.9.
Any and all input appreciated.
Thanks,
Henry
Thanks,
Henry
