Hi all,
Did a search online and at TMC, and couldn't find an answer to a relatively simple question about the climate control system in my Model Y. I realize that the Y has dual climate control for the driver and passenger with independent temperature settings for each (if enabled). I have not found a way to select a temperature for the rear. It appears the only control is turning the rear fan off/on.
Assuming I'm not missing a setting somewhere, what controls the temperature of the air coming from the rear vents? The driver or passenger settings? That is, if my wife (who likes it to be HOT) sets her temperature as the passenger to 85 degrees F and I set it to a more reasonable 72 degrees F, what temperature should my children expect in the backseat?
Thanks in advance.
Thanks in advance.
