This question is for someone who hopefully knows the answer to what is the max fill percentage one can legally fill a conduit with wires. I have an EMT conduit running from the main panel in a bedroom to a junction box in the ceiling of my garage. It already has three 14 gauge and two 12 gauge. I used a conduit fill calculator Conduit Fill Calculator - Best Online Conduit Fill Calculator to figure I'm under 43% if I run two additional 8 gauge wires. When I looked up the California code California Code of Regulations, Title 8, Section 2760. General. I see 50% max so I should be fine. I just wonder if it's supposed to be 40% since I've seen that number referenced in discussions but maybe that's more of an industry standard.
On a side note I have 2 different breakers energizing my livingroom, 1 bathroom, and garage simultaneously so maybe I can lose one of the conduit wires. Need to figure that one out first. I think they built the townhouse that way by accident. I've seen funky things done where I live so it wouldn't surprise me. I turn one breaker off and one on in any combination and all outlets and switches work. I'm going to try to trace the wires and see. One hot wire off one breaker is yellow so that should help, but yellow I think it supposed to be for a ceiling fan or switched power and no ceiling fans are present. The yellow one goes into the garage so I'll pull all the switches(one) and outlets(two) and see if there is a black hot wire coming in from another side then can disconnect either and test.
