Could a departure time be muddling the picture?I normally charge at home and schedule using the Tesla app to start at 00:30. However, recently I have found that the charging started much later, the last time at 05:04. Has anyone else had this problem?
No as the departure time was not set.Could a departure time be muddling the picture?
I am wondering if it is caused by Teslafi which I have running. I have set the home charging schedule to start at 12pm. Could that mean 12pm USA time?Could a departure time be muddling the picture?
It consistently shows charging about 5 hours later than set, I am wondering if this is some discrepancy with the Tesla app setting. I had scheduled charging on the Tesla app set for 00:30 and at the same time on Teslafi at 12:30 pm. I think aslo that it should have been 12:30 am (I always confuse am and pm when 12 o clock is involved).Not IME. I think it is "local timezone for where the car currently is" (I couldn't find anywhere in CONFIG where I have set the timezone ... but I did find reference on Settings : Measurements to "Display times in local timezone when traveling" and "Indicate when time displayed is in a different timezone")
When I've been to France as I come off the Chunnel I get a "+1:00" on the Date/Time value in the logs (which is either time-vs-GMT for the whole world, or just "France is one hour ahead of YOUR normal time")
Help : TesalFi Data Feed
will show raw data - so you should be able to see where CHARGE started - and compare the LOG time with your local time when that actually happened
Controls : Schedules and Reminders
The "View Scheduled Log" (at bottom of page) will show you all events that triggered (during the last week I think)
That may also provide a clue as to whether TeslaFi triggered an event or not. (For example if the Schedule is specifically set to HOME or PLUGGED IN etc. then the "Result" and "Reason" will indicate if that happened, or not)
I have:
Command = "charge_stop". Result / Reason = "Not Sent Vehicle Is Not Charging"
Command = "charge_start". Result / Reason = "False could_not_wake" but one minute later repeated and "True"
